Using CiscoWorks to Check the Active Switch Ports Usage
Jun 27th, 2007
I want to check the total switches ports which are not using for certain period of time (For example - 90days).
I have tried to use CWSI (RME). It can generate the report called "Switch Port Usage-Unused Up" and "Switch Port Usage-Unused down", but it doesn't come with specified period (or time stamp).
Joe Clarke Wed, 06/27/2007 - 20:27
This is addressed in LMS 3.0 which is now shipping. Contact your sales team on how to order LMS 3.0 as there are no upgrades from previous versions of LMS.
yjdabear Fri, 06/29/2007 - 05:16
According to an old post, this is limited to the past six months, correct?
Joe Clarke Fri, 06/29/2007 - 08:13
No, as I later said on that post, the built-in dates can only go back six months, but you can type in any range you'd like.
