MS VPN (PPTP or L2TP) from inside to the internet.
Jun 27th, 2007
I have one cisco asa 5505 up and running, all trafic is working from the inside to the outside except the microsoft vpn (PPTP or L2TP).
The VPN from the outside to the inside and/or dmz is working perfect, (i'm not useing the ms vpn, i'm useing the cisco vpn client).
Is the any exemple configuration that I can look at that is working with microsoft vpn from inside to the internet ???
Mike
tstanik Tue, 07/03/2007 - 13:17
  • Bronze, 100 points or more
Windows clients must use Microsoft Challenge Handshake Authentication Protocol (MS-CHAP) authentication for MPPE to work. If you are performing mutual authentication with MS-CHAP and MPPE, both sides of the tunnel must use the same password
http://www.cisco.com/en/US/products/hw/routers/ps341/products_configuration_guide_chapter09186a0080518a17.html
