CAT5 cable that comes with 7961G-GE phone
Answered Question
Jun 27th, 2007
Anyone knows why Cisco ships 7961G-GE IP phones with Category 5 cables as Cat5 isnt compatible for 1000BASE-T...
Can we request Cisco to ship GE phones with Category 6 or minimum 5e cables?
Eugene
Correct Answer by Paolo Bevilacqua about 9 years 7 months ago
I know, I should get a life..
..one of these days..
thanks for the rating and good luck!
Overall Rating: 4 (3 ratings)
Paolo Bevilacqua Thu, 06/28/2007 - 00:52
Actually 1000 base T was designed for category 5 cabling and works on category 5 cabling.
If you cabling exceed cat 5, good, but is it NOT a requirement.
Worry not, it won't be a 1.5 m patch, whatever category it is, to give trouble to your network.
Hope thos helps, please rate post if it does!
eug-c Thu, 06/28/2007 - 01:41
Thanks for your reply.
I found this from a website about Category 5.
Maybe Cisco would take this as a feedback to upgrade their cables. :)
The original specification for category 5 cable was defined in ANSI/TIA/EIA-568-A, with clarification in TSB-95. These documents specified performance characteristics and test requirements for frequencies of up to 100 MHz.
Paolo Bevilacqua Thu, 06/28/2007 - 02:06
Despite any adverse claim, gigabit ethernet works fine over category 5 cabling. why is that, read in the following article:
http://www.hardwaresecrets.com/article/231
The cat 5e, is a recommendation, not a strict requirement.
The same answer you can find on another variety of sources, wikipedia, etc.
This is not to defend cisco, but when it comes to networking, most of the time they know what they are doing :)
eug-c Thu, 06/28/2007 - 06:53
Thanks man.
I guess in terms of technology it would work. but for my corporate standard, cat 5 is not an option. :(
So I have to purchase either new cat 5e or cat 6 for the ip phones and the default ones have to go to waste. :((
Thanks for your help.
I guess there isn't anything we can do bout it.
You netpros are really pros!
Dun you guys have to work???
look at the points u guys have!!!
haha
Correct Answer
Paolo Bevilacqua Thu, 06/28/2007 - 07:14
