06-28-2007 03:21 AM - edited 03-03-2019 05:39 PM
I am putting in-service a 7206 VXR that was inherited during an acquisition. When I do show ver and show hardware I'm not seeing anything that looks like a serial number. Should I be finding the serial number via these IOS commands or other? Thanks.
Solved! Go to Solution.
06-28-2007 03:54 AM
The serial number for the chassis can be read only physically on the chassis, because the backplane is passive.
The S/N for NPE and cards, you should be able to see with c7200, show inventory (if already implemented in your IOS), show diag.
06-28-2007 03:54 AM
06-28-2007 04:39 AM
I thought that was the case. Thank-you.
06-28-2007 05:13 AM
Maybe the sho snmp command will also give you the chassis serial number, but only if someone has put the serial number in the device with the snmp-server chassis command.
