Problem with connecting VG224 to CCM4.1 (SCCP)
Jun 28th, 2007
I have some problems with connecting VG224 to CCM4.1
I create a new gateway on CCM (VG244-SCCP),create one Phone with directory number. Problem is that status of this phone "Not Found" IP address blunk,and I cant make call from CCM IPPnones to VG244Phones and back.H
Here is my config:
version 12.4
no service pad
service password-encryption
hostname VG224
boot-start-marker
boot-end-marker
enable secret xxx
enable password xxx
no aaa new-model
resource policy
ip subnet-zero
no ip dhcp use vrf connected
voice-card 0
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 192.168.255.59 255.255.255.0
ip access-group 121 in
ip access-group 121 out
no snmp trap link-status
interface FastEthernet0/0.2
encapsulation dot1Q 700
ip address 10.10.0.4 255.255.0.0
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
shutdown
ip classless
no ip http server
voice-port 2/0
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
sccp local FastEthernet0/0.2
sccp ccm 10.10.0.50 identifier 1 version 4.1
sccp ip precedence 1
sccp codec g711ulaw mask
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer voice 77 voip
destination-pattern 77...
voice-class codec 1
session target ipv4:10.10.0.50
dial-peer voice 72 voip
destination-pattern 72...
voice-class codec 1
session target ipv4:10.10.0.2
dial-peer voice 1 pots
destination-pattern 1000
port 2/2
line con 0
line aux 0
line vty 0 4
password xxx
login
end
VG224#
sh sccp all
SCCP Admin State: UP
Gateway IP Address: 10.10.0.4, Port Number: 2000
IP Precedence: 1
User Masked Codec list: g711ulaw
Call Manager: 10.10.0.50, Port Number: 2000
Priority: N/A, Version: 4.1, Identifier: 1
SCCP application services(dspfarm profiles) are not enabled
or haven't associated to SCCP CCM group
CCM Group Identifier: 1
Description: None
Binded Interface: NONE, IP Address: NONE
Associated CCM Id: 1, Priority in this CCM Group: 1
Registration Retries: 3, Registration Timeout: 10 sec
Keepalive Retries: 3, Keepalive Timeout: 30 sec
CCM Connect Retries: 3, CCM Connect Interval: 10 sec
Switchover Method: GRACEFUL, Switchback Method: GRACEFUL_GUARD
Switchback Interval: 10 sec, Switchback Timeout: 7200 sec
Signaling DSCP value: default, Audio DSCP value: default
Total number of active session(s) 0, and connection(s) 0
Total number of active session(s) 0, connection(s) 0, and callegs 0
SCCP Application Service(s) Statistics Summary:
Total Conferencing Sessions: 0, Connections: 0
Total Transcoding Sessions: 0, Connections: 0
Total MTP Sessions: 0, Connections: 0
Total ALG-Phone Sessions: 0, Connections: 0
Total BRI-Phone Sessions: 0, Connections: 0
Total SCCP Sessions: 0, Connections: 0
VG224#
Overall Rating: 5 (1 ratings)
lfulgenzi Thu, 06/28/2007 - 05:52
  • Silver, 250 points or more
Try adding:
stcapp ccm-group 1
stcapp
that should trigger the registration.
seducer666 Thu, 06/28/2007 - 20:35
I add this commands but nothing changes,and I cant add a few commands like "bind interface FastEthernet0/0.2" in the sccp ccm group 1.
seducer666 Fri, 06/29/2007 - 01:17
Here is my new config,CCM see VG224 and analog phones,but I cant make any calls from VG to CCM and back. If look to debug it seems that call from CCM cames to VG,but phone dont ring.
77666 - CCM
77665 - VG
version 12.4
no service pad
hostname VG224
boot-start-marker
boot-end-marker
logging buffered 8000 debugging
enable secret 5 $1$UF1Y$HZdGIlnQMiqMdEnNW06FF.
enable password 7 15141204062C20
no aaa new-model
resource policy
clock timezone MSK 3
clock summer-time MSK recurring last Sun Mar 3:00 last Sun Oct 2:00
ip subnet-zero
stcapp ccm-group 1
stcapp
voice-card 0
voice service voip
voice class codec 1
no ip address
duplex auto
speed auto
ip address 10.10.0.4 255.255.255.0
shutdown
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.0.1
no ip http server
logging trap debugging
access-list 1 permit 192.168.255.0 0.0.0.255
access-list 1 deny any
access-list 121 permit ip 192.168.255.0 0.0.0.255 192.168.255.0 0.0.0.255
control-plane
voice-port 2/0
cptone RU
voice-port 2/1
cptone RU
voice-port 2/2
compand-type a-law
cptone RU
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
sccp ccm 10.10.0.50 identifier 1 priority 1 version 4.1
sccp
sccp ccm group 1
switchback method graceful
voice-class codec 1
dial-peer voice 77665 pots
service stcapp
port 2/2
line con 0
line aux 0
line vty 0 4
password 7 050D1F07234A45
login
end
Jun 29 07:30:44.213: CallInfoMsg Info:
calling party name: Jspc`mnb @.E.
called party name: Test_Analog_Port2
calling party: 77666
called party: 77665
line instance: 1
call reference: 16857831
call type: 1
orig called pty name: Test_Analog_Port2
orig called pty: 77665
last redirecting pty name: Test_Analog_Port2
last redirecting pty: 77665
orig cdpn redirect reason: 0
last redirect reason: 0
cgpn voice mailbox:
cdpn voice mailbox:
orig cdpn voice mailbox:
last redirectvoice mailbox:
call instance: 1
call security status: 0
pres restriction bits: 0
seducer666 Fri, 06/29/2007 - 03:49
OK I chanded protocol from SCCP to MGCP, VG244 and CCM see each other, but I still cant make calls betцeen them, where can be a problem.
version 12.4
no service pad
hostname VG224
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip domain name xxx.org
voice-card 0
voice service voip
voice class codec 1
no ip address
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip classless
no ip http server
control-plane
voice-port 2/0
cptone RU
voice-port 2/1
cptone RU
voice-port 2/2
cptone RU
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
ccm-manager mgcp
no ccm-manager fax protocol cisco
mgcp
mgcp call-agent 10.10.0.50 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp bind control source-interface FastEthernet0/0.2
mgcp bind media source-interface FastEthernet0/0.2
mgcp profile default
voice-class codec 1
voice-class codec 1
description 77665
service mgcpapp
port 2/2
line con 0
line aux 0
line vty 0 4
login
VG224#
VG224#sh ccm-manager
MGCP Domain Name: VG224.xxx.org
Priority Status Host
Primary Registered 10.10.0.50
First Backup None
Second Backup None
Current active Call Manager: 10.10.0.50
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 15:47:11 MSK Jun 29 2007 (elapsed time: 00:00:13)
Last MGCP traffic time: 15:47:11 MSK Jun 29 2007 (elapsed time: 00:00:13)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
Configuration Error History:
FAX mode: disable
VG224#
lfulgenzi Fri, 06/29/2007 - 04:49
MGCP has it's own tricks to look out for. For example, the device name in CCM has to match exactly the hostname+domain name of the router/gateway.
Stick with one protocol and get through that first is my opinion.
I see that you have ACLs on your interfaces. The first thing I would do is remove any ACLs to ensure you can get this working. Minimally, have logging enabled on your ACLs so you can see which ones are being hit.
rsiddon Fri, 09/21/2007 - 13:11
I had to enter the sti to the dial peer from the config documents:
As soon as I added the service to the dial peer, the port registered and I can place calls.
stcapp ccm-group 1
stcapp
dial-peer voice 102 pots
service stcapp
port 2/2
rvincent Fri, 11/16/2007 - 09:59
try adding the following cmds:
stcapp ccm-group 1
stcapp
and a dial peer for each port you will use as follows:
dial-peer voice 501 pots
service stcapp
port 2/0
Rob
