06-28-2007 05:24 AM - edited 03-03-2019 05:39 PM
i have 2 (64kbps) isdn links with 2 dialer strings
i want to connect the remote site at 128 kbps is it possible? if possible config pls
i tried creating a dialer interface and included in pool membership, but it doesnt worked, in article i was said
if i put dialer string 1333223
dialer string 1464313
it will pick only first number, if first fails second will be considered
i want to use two strings with dialer interface ?
any config or tips to do that
06-28-2007 07:00 AM
You have to specify the dial order. Please try teh following example.
interface Dialer0
ip address 10.1.1.130 255.255.255.0
encapsulation ppp
dialer pool 1
dialer string 1904
dialer string 1905
dialer-group 1
dialer order round-robin
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t8/ftrotdls.htm
I think it help a little.
Thanks and Regards,
Srinath.M
Cable&Wireless
06-29-2007 01:35 AM
will allow only one string to be used
i need to use both the strings at the same time
is it possible ?
06-29-2007 02:55 AM
Hi Shiva
As you have pointed out in your earlier mail by defining 2 dialer strings will help only when the first defined dialer string is unavailable...
Have you tried defining 2 dialers instead and assigning induvidual dialer strings onto them ?
regds
06-29-2007 09:09 PM
i tried it is picking only the first dialer string
07-16-2007 08:31 PM
Try using this,it will keep both dial string up,kindly rate it.
interface Dialer0
encapsulation ppp
dialer pool 1
dialer load-threshold 128 either
dialer string 1904
dialer string 1905
dialer-group 1
