RSA New Pin mode
Jagdeep Gambhir Fri, 06/29/2007 - 05:13
  • Red, 2250 points or more
James,
Yes, it should support new pin mode. I've not checked with the specific ver but it works with other codes.
~JG
rochopra Fri, 06/29/2007 - 05:18
  • Cisco Employee,
It works well in the previous version, so should work well with VPN client 5.0 as well.
Jagdeep Gambhir Fri, 06/29/2007 - 09:03
James,
There is a bug, when using the 5.x VPN Client, the VPN Client does not prompt for SecurID
token card authentication information after the first connection.
Conditions
A change to the authentication prompts introduced this new error. The first SecurID connection after opening the GUI works, but after disconnecting the session, a new one can't be established because the user is not prompted for their SecurID token passcode.
Workaround
Close the VPN Client GUI before attempting to make a new connection.
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCsi62282&Subm
it=Search
Hope that helps !
~JG
Jagdeep Gambhir Fri, 06/29/2007 - 11:36
Thanks for your response.
Please mark the thread resolved , so other can benifit.
Thank You !
~JG
