Change Network Card Properties
Jun 28th, 2007
I want to modify some parameters on wired network card on multiple PC windows XP to accept 802.1X PEAP
In fact in the "Authentication" tab, you must choose :
-- EAP Type == Protected EAP(PEAP)
-- Mark the case "Authenticate as computer when information is avaible"
... etc
In fact, how you can modifiy multiple parameters on Network card by script or other thinks without pass on each PC's ????
I have try with LanDesk Software, GPO, and search Registry code but there is no issue ...
If you have solutions
Thanks for your help
