CSS upgrade
Answered Question
Jun 28th, 2007
hello,
I upgraded a CS-150-LAN-02 to the ap0610405 code. Upon reboot, I get the below error messages. If I boot back into the previous code (ap0401040s) I don't the errors. Is there a stair step that needs to be performed or is there something else? Any help would be appreciated. Thanks.
ONDM: EPIF FIFO size is not standard on epif: 0.
ONDM: EPIF FIFO size is not standard on epif: 1.
ONDM: EPIF FIFO size is not standard on epif: 2.
ONDM: EPIF FIFO size is not standard on epif: 3.
JUN 28 09:02:06 5/1 1 SYSSOFT-3: ONDM: EPIF FIFO size is not standard on epif: 0.
JUN 28 09:02:06 5/1 2 SYSSOFT-3: ONDM: EPIF FIFO size is not standard on epif: 1.
JUN 28 09:02:06 5/1 3 SYSSOFT-3: ONDM: EPIF FIFO size is not standard on epif: 2.
JUN 28 09:02:06 5/1 4 SYSSOFT-3: ONDM: EPIF FIFO size is not standard on epif: 3.
Correct Answer by Gilles Dufour about 9 years 8 months ago
this is normal.
We did some changes in the EPIF code in 6.10 and if you upgrade from another version like 5.0 to 6.10 the CSS will display this message.
No worries there.
Gilles.
Overall Rating: 5 (1 ratings)
Correct Answer
Gilles Dufour Thu, 06/28/2007 - 11:03
this is normal.
No worries there.
Gilles.
