VPN client. RDP problems (Terminal Server) after migrating from PIX to ASA
Jun 28th, 2007
I have migrated from PIX515E with VPN client configured and working fine to a pair of ASA 5520 with active-standby scheme. All is working fine but I have a problem with RDP and file sharing.
When I connect to the VPN with the client I can ping the server, and I can access to shared folders, but almost everytime I get disconnected from the server with "Encryption Error" at Remote Desktop client. VPN client keeps connected and I can ping the server.
Whe I am connected to the VPN I am able to begin copying files but after some seconds or minutes the file transmision gets disconnected. VPN clients keeps connected and I can ping the server.
I have tried to set MTU to 1300 at client and I have configured "sysopt connection tcpmss 1300" at ASA with no luck.
Any idea ??
Thanks a lot.
Best regards,
r.carreras Sun, 07/01/2007 - 11:38
I have found a workaround for this problem. I have disabled "Instant Messaging" inspection and now it seems that it's working fine.
Is this a "bug" ???
Thank you.
pornthip_k Sun, 07/15/2007 - 05:16
I got the problem likt you.
How to result this issue?
Thank you.
r.carreras Mon, 07/16/2007 - 03:38
It was needed to disable instant messenger traffic inspection.
I have not been able to turn on messenger traffic inspection without VPN problems.
