Pix 506e - Upgrading PDM - syntax?
Answered Question
I'm trying to upgrade my PDM from V3.0(2) to V3.0(3), this is supposed to resolve some issues of connecting to the PDM with newer versions of Java.
Below is the syntax I'm typing in during a hyperterminal session. Obviously it isn't working. Can someone give me the correct syntax?
Copy tftp //tftp-root/pdm-304.bin flash pdm
Correct Answer by vitripat about 9 years 6 months ago
Try using following command syntax-
PIX# copy tftp flash:pdm
Address or name of remote host []? x.x.x.x
Source file name [mybackup]? pdm-303.bin
copying tftp://x.x.x.x/pdm-303.bin to flash:pdm
[yes|no|again]? yes
Assuming that x.x.x.x is the IP address of your TFTP server and pdm-303.bin is the image name.
Hope this helps.
Vibhor.
Overall Rating: 5 (2 ratings)
Correct Answer
vitripat Thu, 06/28/2007 - 07:26
[yes|no|again]? yes
Hope this helps.
Vibhor.
