Newbie Pix to Pix hardware VPN
I have just finished the initial install of three new Pix 506E's at three different offices. I want to create a site to site VPN between the office(s), but I am having some problems. I have worked with Cisco products for years, but never had to deal with VPN's. I setup the a VPN with the PDN using the VPN Wizard, but it seems like it is missing something. DO I just need to setup the VPN, then add a static route to the internal network of the other PIX?
Jon Marshall Thu, 06/28/2007 - 23:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi John
You don't need a static route on your pix for the VPN to work.
When you create the VPN you create crypto access-lists which define which traffic on the pix needs to be encrypted so in your example
Pix A
access-list vpntraffic permit ip 192.168.0.x 255.255.255.0 10.10.0.x 255.255.255.0
Pix B
access-list vpntraffic permit ip 10.10.0.x 255.255.255.0 192.168.0.x 255.255.255.0
These access-lists tell the pix which traffic is to be encrypted. When a packet that matches this access-list is received the pix encrypts it and then sends it to the remote peer IP address. In other words
Pix A knows the remote address of Pix B's outside interface.
Pix A receives a packet destined for 10.10.0.x and sees that it needs to be encrypted. It encrypts it and then sends the packet to Pix B's outside interface.
Pix B decrypts the packet and forwards it on to the 10.10.0.x host.
If you cannot get your VPN working could you post the pix configs minus any sensitive information.
Jon
