Applying Cor Lists to Analog phones
Jun 28th, 2007
I am unable to test this at the moment but can you apply cor lists to analog phones to block outgoing calls to certain numbers
With Thanks
lfulgenzi Thu, 06/28/2007 - 08:05
I configured a VG224 as SCCP to failover to an SRST router and I was able to apply CoR lists effectively.
If you are using something else, like MGCP or H323 then you might have to apply the CoR lists on the gateway itself.
Tell us a little bit more about your config.
mark_gardner Thu, 06/28/2007 - 11:25
Fairly simple setup, cme 4.1, 2851 ISR, E1 pri plus 4 FXO analogs, 8 FXS ports, several legacy analog phones potted around the building in basement, lifts etc, want to configure these phones to allow internal and local calls only.
lfulgenzi Thu, 06/28/2007 - 11:38
According to this document you can apply a corlist to an ephone DN. So you should be good to go.
All you have to do is setup the incoming corlist on the ephone to be a superset of the outgoing corlist on the dialpeer which allows outbound calling.
I found it easier to make each outbound dialpeer's cor list to have only one member and then make sure that the ephone's incoming corlist also has that member.
cor (ephone-dn)
To configure a class of restriction (COR) on the dial peers associated with a directory number, use the cor command in ephone-dn configuration mode. To disable COR associated with a directory number, use the no form of this command.
cor {incoming | outgoing} cor-list-name
no cor cor-list-name
