Configuring direct lines for managers on FXO cards
Answered Question
Jun 28th, 2007
Hi all
I have this configuration below in a cisco 2801 router running CCME. I have configured connection Plar directing external calls to specific extensions. I have a problem with ensuring that outbound calls from a manager on extension 203 are always routed to voice port 0/0/0 and that all other outbound calls from other users don't ever use this voice port 0/0/0. The main aim is having a fixed/direct line for manager on extension 203.
voice-port 0/0/0
dial-type pulse
no non-linear
cptone GB
connection plar opx 203
impedance complex2
caller-id enable
voice-port 0/0/1
dial-type pulse
no non-linear
cptone GB
connection plar opx 206
impedance complex2
caller-id enable
voice-port 0/0/2
dial-type pulse
no non-linear
cptone GB
connection plar opx 208
impedance complex2
caller-id enable
voice-port 0/0/3
dial-type pulse
no non-linear
cptone GB
connection plar opx 207
impedance complex2
caller-id enable
dial-peer voice 1 pots
preference 2
destination-pattern 9T
port 0/0/0
dial-peer voice 2 pots
port 0/0/1
dial-peer voice 3 pots
preference 1
port 0/0/2
dial-peer voice 4 pots
port 0/0/3
dial-peer voice 203 voip
destination-pattern 203
session target ipv4:192.168.42.1
dtmf-relay h245-signal
codec g711ulaw
dial-peer voice 206 voip
destination-pattern 206
codec g711ulaw
dial-peer voice 208 voip
destination-pattern 208
codec g711ulaw
dial-peer voice 207 voip
destination-pattern 207
codec g711ulaw
Sollo
Correct Answer by paolo bevilacqua about 9 years 11 months ago
Overall Rating: 5 (1 ratings)
