06-28-2007 07:52 AM - edited 03-14-2019 10:19 PM
I have a issue and was wondering if some in the post have a workaround.
A remote site that invokes AAR has problems when the press the message button. They get the general greeting.
Is there way to fix this without going to every sub account in unity and creating a alias.
I also noticed on the gateway pri in front of the unity box i get the unity pilot number called... when i do a test call
I noticed that the voicemail hunt pilot has a aar group field and a external mask as well what are is the purpose of these fields.
The remote site has did's for every station
Solved! Go to Solution.
06-28-2007 09:31 AM
The AAR group and external phone number mask together determine the prefix and phone number that phones will dial when AAR is invoked. First, you will need to make sure that your carrier supports RDNIS as this is required for this scenario to work. Also, make sure that Redirecting Number IE Delivery is enabled outbound on the remote gateway and inbound on the gateway at the Unity site. Take a look at the following link.
Hope this helps. If so, please rate the post.
Brandon
06-28-2007 09:31 AM
Brandon
