Using 72pin, 70ns Parity memory in 3640 routers?
Jun 28th, 2007
I am upgrading a half dozen 3640's to 128MB RAM. From my searching, it appears the 3640 requires 60ns, Parity or NON-parity, 72pin EDO memory. Looking at Cisco web-site not clear on this.
I have installed some IBM 72pin, 70ns, Gold-lead, Parity memory in all four SIMM slots in my 3640. It boots up fine, in 64 bit, Parity mode! Am I at risk of damaging my router?
Another router booted fine using IBM 72pin, 60ns, Parity, Gold-lead EDO memory from an old IBM Aptiva computer. Again, is this a potential problem? Thanks so much for advice. Would hate to meltdown my new-found test lab!!!
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Thu, 06/28/2007 - 08:13
No you don't risk to damage the router.
The only thing is, the slots used by cisco are of the tin type and would require tin-plated ram modules. With the gold-plated ones, you risk damage to due to corrosive reaction in the longer term. So it would be better to use tin-plated module.
I know a very reputable vendor that I can pass to you if you contact me to the address in my profile.
jamesd058 Thu, 06/28/2007 - 11:21
Thanks for the info and offer. As this is a test lab only I'll see how it goes. Appreciate it.
