remote vpn try to ping inside network
Answered Question
Jun 28th, 2007
i am using this setup
i cannot ping the inside user from the remote client ?
do you know why ?
Correct Answer by acomiskey about 9 years 4 months ago
management-access inside
Please rate helpful posts.
Overall Rating: 5 (1 ratings)
dcoulanges Thu, 06/28/2007 - 10:41
I am at home receive a ip address and i couldnot ping the inside interface of the pix 501(
this the partial of the config( i remove line command for security)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
access-list outside_access_in permit icmp any any echo-reply
access-list 101 permit ip
ip address inside
ip local pool ippool
global (outside) 1 interface
nat (inside) 0 access-list 101
nat (inside) 1 0 0
access-group outside_access_in in interface outside
sysopt connection permit-ipsec
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap client authentication LOCAL
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp policy 8 authentication rsa-sig
isakmp policy 8 encryption des
isakmp policy 8 hash sha
isakmp policy 8 group 1
isakmp policy 8 lifetime 86400
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup vpn3000 address-pool ippool
vpngroup vpn3000 split-tunnel 101
vpngroup vpn3000 idle-time 1800
vpngroup vpn3000 device-pass-through
vpngroup vpn3000 password ********
Correct Answer
acomiskey Thu, 06/28/2007 - 11:03
