Adding a second subscriber
Answered Question
Jun 28th, 2007
Does do I need to get another license if I want to add a second subscriber into my call manager cluster? I know how to add a second subscriber, but I want to make sure that after 30 days the new/second subscriber doesn't shutdown because we're in evaluation mode or something similar. Like I discovered the hard way with unity.
For what its worth, my call manager version is 4.1.3sr5b. I have 1 publisher and 1 subscriber; i'd like to add one more subscriber to take some of the load off the other two boxes.
Correct Answer by mchandak about 9 years 10 months ago
You dont need to add any license file to add Additional CallManagers upto CM 4.x. With CM 5.x you need a NODE License to be installed for every callmanager in the cluster.
Overall Rating: 4 (3 ratings)
Correct Answer
mchandak Thu, 06/28/2007 - 11:04
  • Gold, 750 points or more
ricky-li Mon, 07/09/2007 - 12:50
Thanks, for now i'm sticking to CM 4.1sr5b. But good to know that when I go CM5 i'll need to purchase licenses.
thisisshanky Thu, 06/28/2007 - 11:05
  • Purple, 4500 points or more
You have to buy a server, and the CM software.
CM4.1-K9-78XXI1-1
XX = 25, 35, 45, depending on the server you are getting.
The server part no will be
MCS-78XX-AB-IPC1
where XX = 25,35,45
B = 1,2, (H1, H2, I1, I2)
A = H for HP or I for IBM
Sankar
PS: please remember to rate posts!
ricky-li Mon, 07/09/2007 - 12:27
Thanks, actually i have an existing MCS-7825 sitting around that was used for an old Unity installation. That I want bring it back into service as a secondary subscriber.
yes long story short, before I got to this job the previous admin bought 3 MCS-7825 for pub, sub and Unity. Even though unity could have gone on any generic server.
