upgrading from asa711-k8.bin to asa 721-k8.bin error
Jun 28th, 2007
when i am trying to upgrade to the new image i get this error
test(config)# boot config disk0:/asa721-k8.bin
ERROR: Unable to set this url, file has non-ASCII characters
srue Thu, 06/28/2007 - 11:46
  • Blue, 1500 points or more
boot system is the command you need
goonyee268 Thu, 06/28/2007 - 11:53
Hi Srue,
I used that command and it is already tag. How do I set the order of the boot files? I have asa711-k8.bin as startup but i want to use the asa721-k8.bin as the boot image.
acomiskey Thu, 06/28/2007 - 12:01
  • Green, 3000 points or more
Like srue said, use the boot system command. It will boot to the first in the list.
boot system disk0:/asa721-k8.bin
boot system disk0:/asa711-k8.bin
FirewallEngineer Sat, 05/05/2012 - 09:26
I believe this error message is occurred because the command is not put in the right order.
I've tested a few times in GNS3 and I believe the right sequences are as follows:
enable
config t
copy run disk0:/.private/startup-config
boot config disk0:/.private/startup-config
wr mem
I hope this helps.
Btw, I've also documented it here.
http://firewallengineer.wordpress.com/2012/05/06/solved-error-unable-to-set-this-url-file-has-non-ascii-characters/
chgallup Wed, 09/05/2012 - 11:43
Firewall# show bootvar
Firewall# dir flash
Firewall# configure terminal
Firewall(config)# boot system flash:/image.bin
Firewall(config)# exit
Firewall# copy running-config startup-config
Firewall#
BOOT variable = disk0:/asa841-k8.bin
