EDGE SERVICE: MANAGED IP ROUTER
Jun 28th, 2007
Recently, I've been working on getting a Service Provider Company certified on MSCP Edge Service: IP Routing. I cant find much on the website, even less on the internet. So I was wondering I you could help me with the following.
I would like to know, which Managed Services fall into the, Edge Service: IP Routin, category?
paolo bevilacqua Thu, 06/28/2007 - 13:37
  • Hall of Fame,
    Founding Member
Hi, these are simply cisco definitions to profile a type of network and do not necessarily map to an exact design or device.
For example, edge router is a router with WAN interface speeds between 1.5 and 45 mbps.
Managed services is when a customer gives all the routers configuration and monitoring to a service provider.
Nothing more technical.
