Trust DSCP on WS-X6348-RJ-45 using Native IOS
Jun 28th, 2007
I need to be able to trust DSCP on the follow 10/100 module WS-X6348-RJ-45 running Native IOS. Currently I can't trust any thing and have to use the MQC type config to classify and mark packets...Problem is I don't know all the traffic that needs to be marked or what it needs to be marked(Avaya voice system)....I would like to trust the ports to at least figure that out....Anyone know of a way. I have done it in CatOS before.
Overall Rating: 5 (1 ratings)
royalblues Thu, 06/28/2007 - 13:12
  • Green, 3000 points or more
QoS is by default disabled in 65XX.
Mls qos will enable qos globally on the switch
you can trust the port by using mls qos trust dscp or mls qos trust cos command
Narayan
MICHAEL WAISBROT Thu, 06/28/2007 - 14:15
Actually that command does not work on the module I mentioned above...Believe me I tried that.
Jon Marshall Thu, 06/28/2007 - 22:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
As Narayan said you can use either "mls qos trust dscp" or "mls qos trust cos". Looking at our 6500 on our lab with the WS-X6348-RJ-45 module the "mls qos trust dscp" command is not available.
Do the Avaya phones mark the Cos value as well as you could use the "mls qos trust cos" command for this module.
Jon
chrihussey Fri, 06/29/2007 - 03:52
  • Silver, 250 points or more
I ran into a similar problem and this may help. It is unfortunate that you cannot use the trust dscp command with this module and in some versions of code it let's you use it but it still won't work!
Regardless - If you have a general idea of the QoS/DSCP markings used by the Avaya system you can tell the switch to remark the packets with the same DSCP settings that are on the incoming packets. If you can sniff the port you may get a good idea of the markings so as not to make the process too cumbersome. See example below:
interface FastEthernet4/5
ip address 10.X.X.4 255.255.255.0
load-interval 30
speed 100
duplex full
service-policy input VOIP
Global config:
class-map match-all voice_ctl
match access-group 112
match access-group 111
policy-map VOIP
class voice
set dscp ef
class voice_ctl
set dscp af31
access-list 111 permit ip any any dscp ef
access-list 112 permit ip any any dscp af31
MICHAEL WAISBROT Fri, 06/29/2007 - 05:27
Thanks, That is a great idea to use the dscp values in the acl's. didn't know you could do that. I was trying to figure out the actually tcp and udp ports the Avaya system is using(which apparently isn't the default).
I will give it a shot.
MICHAEL WAISBROT Fri, 06/29/2007 - 05:40
That did work great. I was able to see the packets and what ports are being used.
chrihussey Fri, 06/29/2007 - 05:46
That's great....glad I was able to help
