Dymanic Vlan question
Jun 28th, 2007
i wanted to set up a vmps server so that pc's in our building can move ports on the switches while retaining their correct vlans. i wanted to know if this was possible without a ACS server? amy help would be great
sundar.palaniappan Thu, 06/28/2007 - 14:04
  • Green, 3000 points or more
Darren,
I haven't personally implemented VMPS. However, the following documentation doesn't seem to indicate you need an ACS. You just need a TFTP server to store the VMPS database from which the switch would extract the VLAN info for the user's MAC address.
http://cisco.com/en/US/docs/switches/lan/catalyst5000/catos/6.x/configuration/guide/vmps.html#wp1019985
Sundar
ggt-cisco Mon, 07/09/2007 - 14:19
That's correct, you don't need ACS at all.
Furthermore, if you don't have a switch capable of being a VPMS server, you can still deploy it with an open source vmps server, such as http://vmps.sourceforge.net. I have used it and it works fine.
Rafa
stephen.stack Wed, 07/11/2007 - 10:16
  • Silver, 250 points or more
Sorry for jumping on this post, but i have a question relating to it. :)
I need to implement dynamic VLANs too and i have investigated OpenVMPS. I am not a linux buff, but i can find my way around. ggt-cisco, was it easy or difficult for you to get setup? Have you had any problems? Is there any tips or easy ways to get this installed from your experience?
Stephen
