1410 link up (working fine) and suddenly stop transmit
Jun 28th, 2007
I have a point to point link using 1410 bridges with wpa phrase. there are working fine but suddly after 2 to 3 weeks stop transmiting but there are still associated and can?t ping one each other
any ideas?
c1410-k9w7-mx.123-8.JEA
pnegi Fri, 06/29/2007 - 06:39
May I know how these bridges are connected to your network?
What is the IOS versions on both bridges?
Did you make any changes to them?
Did you check the association status after refreshing it?
What is the radio state on non root bridge?
Are you using external antennas? If yes, then what type of antenna are you using?
What is the signal strength?
sdeltoro1 Thu, 07/05/2007 - 09:36
Hi, thanks for answering.
the bridge are point to point
the ios is: c1410-k9w7-tar.123-11.JA1.tar
no changes actually: and the association seem to be fine but not ping each other. I?m using the integrated antennas.
association -58 and channel 149 (5745) and I put a file with some commands.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
