Firewall DHCP Relay
Jun 28th, 2007
Hello, is it possible to do DHCP relay with DHCP client on outside (lower security interface) and DHCP server on inside (higher security interface)? The documentation and examples only mention a scenario with DHCP client on inside interface and DHCP server on outside interface. Thank you.
JBDanford2002 Thu, 06/28/2007 - 15:51
Never tried it before. Docmentation says specifically to inside interface but I know you can do it on more than just the inside interface. What really distinguishes the interface is the security level. I would try it. Post the results here. I know you can add your DHCP server on the inside interface.
lbhoang Thu, 06/28/2007 - 15:55
My question is in regards to FWSM 2.3(3)2 and PIX 6.3(5). Thank you.
