TE Tunnel won't come up
Answered Question
Jun 28th, 2007
I've been racking my brain on this for hours. I need a cluebat.
!R1:
mpls traffic-eng tunnels
mpls ldp loop-detection
pseudowire-class ATOM-E
encapsulation mpls
interworking ethernet
interface Tunnel1
ip unnumbered Loopback0
load-interval 30
tunnel source Loopback0
tunnel destination 200.20.55.2
tunnel mode mpls traffic-eng
tunnel mpls traffic-eng priority 7 7
tunnel mpls traffic-eng bandwidth 100
interface Loopback0
ip address 200.x.x.x.255.255.255
interface GigabitEthernet0/2
ip address 200.x.x.1 255.255.255.0
media-type rj45
speed auto
duplex auto
no negotiation auto
mpls ip
ip rsvp bandwidth 1000
interface GigabitEthernet0/3
no ip address
media-type rj45
speed auto
duplex auto
negotiation auto
interface GigabitEthernet0/3.10
encapsulation dot1Q 10
no snmp trap link-status
xconnect 200.20.55.2 10 pw-class ATOM-E
router ospf 100
log-adjacency-changes
redistribute connected subnets
network 200.20.55.1 0.0.0.0 area 0
network 200.100.55.0 0.0.0.255 area 0
mpls traffic-eng router-id Loopback0
mpls traffic-eng area 0
mpls ldp router-id Loopback0 force
!R2
encapsulation mpls
interface Tunnel1
load-interval 30
tunnel destination 200.20.55.1
interface Loopback0
ip address 200.x.x.2 255.255.255.255
ip address 200.x.x.2 255.255.255.0
media-type rj45
speed auto
duplex auto
negotiation auto
mpls ip
no ip address
media-type rj45
speed auto
duplex auto
negotiation auto
interface GigabitEthernet0/3.20
encapsulation dot1Q 20
xconnect 200.20.55.1 10 pw-class ATOM-E
router ospf 100
network 200.20.55.2 0.0.0.0 area 0
R1's loopback can ping R2's loopback:
R1#ping ip 200.20.55.2 source lo0
Sending 5, 100-byte ICMP Echos to 200.20.55.2, timeout is 2 seconds:
Packet sent with a source address of 200.20.55.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
R1#
R2's loopback can ping R1's loopback:
R2#ping ip 200.20.55.1 source lo0
Sending 5, 100-byte ICMP Echos to 200.20.55.1, timeout is 2 seconds:
Packet sent with a source address of 200.20.55.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
R2#
All looks well, but the TE tunnels are up/down and I can't for the life of me figure out why!
R1#show ip int brie | incl Tun
Tunnel1 200.20.55.1 YES TFTP up down
R1#
R2#show ip int brie | incl Tun
Tunnel1 200.20.55.2 YES TFTP up down
R2#
Correct Answer by swaroop.potdar about 9 years 8 months ago
Good...
You can try using different path options and see the difference.
You can also try going through this document to play around with the advanced topics in TE.
http://www.cisco.com/en/US/tech/tk436/tk428/technologies_white_paper09186a00800a4472.shtml
HTH-Cheers,
Swaroop
1) When you issue the "show mpls traffic-eng tunn" you will see the error why the tunnel is not setup. It will say Invalid Path option.
To solve it you will have to define a path-option for the TE tunnel, so that it can use it to setup the path till the destination.
2) And also you tunnel destination is to be the loopback of the other router. you can use the interface address in the explicit path option.
HTH-Cheers,
Swaroop
Overall Rating: 5 (2 ratings)
Correct Answer
swaroop.potdar Thu, 06/28/2007 - 17:34
HTH-Cheers,
Swaroop
jlixfeld Thu, 06/28/2007 - 17:36
Figured it out from other posts:
Need "tunnel mpls traffic-eng path-option 1 dynamic" on the tunnel interface. No configuration examples specified this.
