WIC-1DSU-T1
rileymartin
I'm putting together a CCNA/CCNP lab and I have two 1720's with WIC-1DSU-T1 interface cards. Can I connect the two 1720's with the WIC-1DSU-T1 interfaces like you would with serial ports? Do I need an ethernet cable with any special pinouts? Thanks.
Riley
spremkumar
Level 9
Level 9
Hi Martin
As per the cable specs its general 1,2 & 4,5 combination which carries both Tx/Rx signals.
You can try connecting 1,2/4,5 on one end and reversing the same at the other end.
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a00801f5d89.shtml
for config assistance do refer the below link..
http://www.cisco.com/en/US/products/hw/modules/ps3129/products_tech_note09186a00800b1501.shtml
regds
Agree with Edwin, i think that i've tried this before, but make sure that one of the 2 ends is supplying the clocking using the "service-module t1 clock source internal" command, and the other having "service-module t1 clock source line", please check this document:
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a00800a3f09.shtml#command
HTH,
Mohammed Mahmoud.
mbroberson1
Level 3
Level 3
Yes you can do this. I do this in my home lab to simulate a WAN T-1 connection. You will been to make a "T-1 crossover cable".
http://www.voip-info.org/wiki/view/crossover+T1+cable
Brandon
