QoS on the Aironet1240AG
Jun 28th, 2007
Hi all,
I'm using 2 AP to configure a bridge between the main network and a remote switch. The bridge is working well. There are 2 flows : ip voice and data.
The voice traffic has QoS implemented. Indeed, the DSCP field indicates that de class is EF (expedited forwarding). My question is very simple : "does the AP apply a treatment on the voice flow automaticaly even if no QoS policy is defined on the AP ? (because the traffic is already tagged) "
I thank you all in advance for your answers
carenas123 Wed, 07/04/2007 - 10:58
  • Silver, 250 points or more
When you configure QoS, you create QoS policies and apply the policies to the VLANs configured on your access point. If you do not use VLANs on your network, you can apply your QoS policies to the access point's Ethernet and radio ports. REfe rURL
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1200/accsspts/b1238ja/1238jasc/s38qos.htm#wp1053895.
Note:Misleading information:WMM is not enabled by default. It has to be confiugred manually
