CM5.0 tftp upload
Jun 28th, 2007
I've been trying to create a background for the phone when it goes on idle. I've uploaded it onto cm in the logo folder which i've created. Then when i paste the url http://xxx.xxx.xxx.xxx/tftp/logo/idle.xml it couldn't be found. I've tried to browse it on my laptop as well and it's shows a page not found. The xml file is correct because i've put the exact same file on a cm 4 server and the phone is able to show the idle background.
Any idea what i've done wrong?
b.hsu Mon, 07/09/2007 - 05:53
Note that you have to upload the following files to the 320x212x12 directory:
List.xml
.jpg
TN-
When uploading to CM5.0 you have to enter "320x212x12/" as the subdirectory name
