MSFC not applying Radius attribute 11 to client VPN connections
Jun 28th, 2007
I have an MSFC with 12.2(18)SXF6 and a VPNSM configured for radius authentication and authorization. In the attachment, I can see the filter-id sent, but when I connect, I can still ping addresses other than in 10.1.x.x, which the acl should disallow. TAC has told me to use aaa authorization configuration default, but I wonder if I should use aaa authorization network default instead. Is there any other reason why the MSFC would not apply the filter to a VPN client connection? Thanks
mflanigan Fri, 06/29/2007 - 00:06
One interesting thing I note, is that if I set the filter id to clientacl.in, the connection fails, even though the radius debug indicates an access-accept back from the server. This indicates that the MSFC is doing something with the attribute, but isn't filtering traffic.
BTW, the radius server is RSA, if that matters.
