06-29-2007 12:38 AM - edited 03-11-2019 03:37 AM
If I have 2 sites, both using Cisco877-SEC-K9 connect to Internet via ADSL with static IP. I can setup a VPN site-to-site connection between them via IPSec.
Is it possible for me to allow teleworker to remote connect to those sites (using VPN client)? I must create Easy VPN on each sites or what?
I read on Cisco 870 data-sheet that Cisco870 supports 10 VPN connection. That means 1 site-to-site & 9 remote VPN?
Thank you,
Solved! Go to Solution.
06-29-2007 12:44 AM
Yes, you can terminate both site-to-site and remote access VPN tunnels on the same router. You can use EASY VPN if you want but you don't have to.
10 VPN tunnels means just that, it is not broken down into x number of site-to-site and x number of remote access. It just means you can have a total of 10 tunnels whichever type they are.
Jon
06-29-2007 12:44 AM
Jon
