2948 Switch & SNMP
Hi All,
I am trying to set up SNMP on a 2948 switch, using CatOS. I have entered the following...
set snmp community read-write <string>
set snmp trap enable module
set snmp trap enable chassis
set snmp trap enable bridge
set snmp trap enable repeater
set snmp trap enable vtp
set snmp trap enable auth
set snmp trap enable ippermit
set snmp trap enable vmps
set snmp trap enable entity
set snmp trap enable config
set snmp trap enable stpx
set snmp trap enable syslog
set snmp trap enable system
but I still cannot seem to get is too work! any ideas?
Thanks for your help!
Overall Rating: 3 (2 ratings)
What do you want to achive?
You have an apps which send snmp quiry to the swithc to get same statistics or you use an apps listens for snmp traps or both. If you use only traps you have to configure where to send the traps. Honestly I'm not familiar with CatOS but in general that's the way.
Hope it helps,
Krisztian
glen.grant Fri, 06/29/2007 - 03:23
  • Purple, 4500 points or more
You need an snmp host to send the traps though it should show up in the logs . Show logg buffer 1000 should show you the logs . To set an snmp host "set snmp trap enable"
guruprasadr Fri, 06/29/2007 - 03:47
  • Gold, 750 points or more
HI Steven, [Pls Rate if Helps]
Default SNMP Configuration consists of 4 Steps:
1. Define the SNMP community strings for each access type.
Syntax:
set snmp community read-only community_string
set snmp community read-write community_string
set snmp community read-write-all community_string
2. Assign a trap receiver and community. You can specify up to ten trap receivers.
Syntax:
set snmp trap rcvr_address rcvr_community
3. Specify the SNMP traps to send to the trap receiver.
Syntax:
set snmp trap enable [all | module | chassis | bridge | repeater | auth | vtp | ippermit | vmps | config | entity | stpx]
4. Verify the SNMP configuration.
Syntax:
show snmp
I see STEP:2 is missing in your Configuration. Pls Verify the Syntax above & configure the same in the Switch.
You need to specify the Trap Receiver (IP of SNMP Collection PC).
PLS RATE if HELPS
Best Regards,
Guru Prasad R
