JAVA Filter with ASA Release 7.x
Jun 29th, 2007
I am trying to configure Java filter on ASA Rel 7.2.2. I am not sure why sometimes my config filters Java applets and sometimes not. The documentation it is mentioned that http inspect is necessary with the filter commands.
The same sites are correct filtered with IOS inspects and PIX 6.3 filter commands.
the configuration:
policy-map type inspect http http1
parameters
match response body java-applet
mask
match response body active-x
mask
policy-map global_policy
class inspection_default
inspect http http1
filter java 80 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0
filter activex 80 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0
service-policy global_policy global
regards,
Herbert
JBDanford2002 Sat, 06/30/2007 - 06:00
Can you give an example of a site where the java applet is not being blocked?
ehuamannahui Tue, 07/24/2007 - 22:56
Hello, does anybody knows if that configuration can be set for individual no global, if that's possible what should be the configuration.
