MARS: problem with report generation
Jun 29th, 2007
hi,
we want to generate a scheduled report which shows how many high, medium and low severity incidents were fired during the configured time range (e.g one month).
to give a better imagination what i mean - it should exactly look like the "Incidents, last ....." graph presented on the "summary" - "network
status" page.
Unfortunatly we didn't found a possibility to create a report which lead's to same output like the addressed graphic.
The Problem seems to be the restricted choice-possibilities when creating reports (?)
The annoying fact is, that the MARS is definitely able to do the corresponding queries to the database - otherwise we won't see the graphic
including a legend on the "network status" page.....'(?)
It again looks like a bad over-all design of the MARS... ;-(
Has anyone of you an idea how we get the needed information into scheduled report? maybe someone knows a report which delivers similar aggregated
output?
best regards
Overall Rating: 4 (1 ratings)
mhellman Fri, 06/29/2007 - 09:10
Would just using the exact graphic you're talking about work? On the 1st of each month, Right-click and save?
In Cisco's defense, reports in a system like this are a pain. every customer wants something different. Personally, I'd like to see them open up network access to the database so I can get the exact reports I want.
We have had to export data using daily scheduled reports and load it in another db. We can then slice-n-dice all we want on that db.
