Hot-plug port adaptor for 7301 router?
Jun 29th, 2007
We have and empty slot and a GBIC port adaptor card with an ZX GBIC installed. Can this be installed into the router online or do I have to power it off?
Fredrik Hofgren
spremkumar Fri, 06/29/2007 - 02:44
Hi Frederik
You can install the GBIC Module onto the slot and start configuring it as per your requirement...
hoffa2000 Fri, 06/29/2007 - 07:45
Thank you for your response. But is it also possible to install and use the entire port adaptor online?
