Reg:WS-c3750- 48TS-E
Jun 29th, 2007
Dear sir,
iwant clarification and details of this switch
Lan switch 48 ports(100base Fx-16 ports,100base T-16 ports,1000 base LH-2ports)this is the my customer requirement in his network.
srinivas.D
Overall Rating: 4 (1 ratings)
vasuramnet Fri, 06/29/2007 - 02:57
hello sir,
what the customer is asking it will support for 4500 chasis series? it means he mentioned in his BOM 16 port 10/100 FX, 16 Port 10/100 Base-T, 2 LH ports.
I think 16 ports not available only 24 port is available in 4500 chasis series?
pl confirm me immediately.
regards,
srini
spremkumar Fri, 06/29/2007 - 03:07
  • Red, 2250 points or more
Hi Srini
You dont have 16 port line cards available either you need to go for 24 or 32 or 48 port line cards..
You can check this product reference document on the kinda modules supported in Cisco 4500 Series switch and the GBIC/SFP which you can install to achieve the above customer expectations...
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheet0900aecd801792b1.html
regds
