CCM 4.2 Changing code pin minimum size
Jun 29th, 2007
Is there's a way to change the minimum size of the user's code pin from 5 to 4 caracters.
Thanks for your answer
ccr_cisco Fri, 06/29/2007 - 06:10
Thanks for your answer but I have an active directory integration so I think this technote is not the good one.
Is there the same procedure for AD.
rob.huffman Fri, 06/29/2007 - 11:05
Hi Morgan,
Sorry about that :) Have a look at this recent post that relates to AD rather than DC Directory and the good answer from Gonz @ Cisco Systems;
Hope this helps!
