Cisco ACS 1113 Appliance v4.1 - RSA Securid v6.1 integration
Answered Question
Jun 29th, 2007
The Windows version of Cisco ACS appears to have the ability to integrate with RSA Securid as its listed in the External Databases. It also can support the SDI protocol if you install the agent on the ACS Windows platform. I need to use a Cisco ACS 1113 appliance but RSA Securid does not appear under the External databases section. Does this mean I will not be able to use the SDI protocol only RADIUS available.
Correct Answer by Premdeep Banga about 9 years 11 months ago
And yes you are correct,
With ACS SE, We need to configure it using Radius, on ACS SE it wont work with SDI.
Prem
Overall Rating: 4.7 (8 ratings)
mark.cronin Sun, 06/24/2007 - 04:41
Do you know when this will be integrated in to the ACS appliance ver 5???
Premdeep Banga Fri, 06/29/2007 - 05:01
  • Gold, 750 points or more
Mark,
This is for ACS SE, as you can see we do not have Secure ID option.
Though its for 3.3, but same works for 4.x
Prem
mark.cronin Fri, 06/29/2007 - 05:00
Rohit
OK this looks ok.
Do you agree that the authentication traffic between the ACS and the RSA Server is RADIUS not SDI which the Windows version of ACS can support
Mark
Correct Answer
Premdeep Banga Fri, 06/29/2007 - 05:04
Prem
Premdeep Banga Fri, 06/29/2007 - 05:07
And reason for that is, because when we configure .conf file, it needs to be imported on ACS SE, which is currently not an option, which is there on ACS for windows.
Prem
