PEAP and Windows 2000
Jun 29th, 2007
For those who use WPA/TKIP/PEAP, have you been able to authenticate on a Windows 2000 computer using the Wireless Configuration service? The only way I've been able to successfully connect to the WLAN is by using a wireless adapter that has a built-in supplicant. Any comments will be appreciated.
Overall Rating: 5 (1 ratings)
Jagdeep Gambhir Fri, 06/29/2007 - 08:27
  • Red, 2250 points or more
Hi ,
If the client is Win2k SP4, then you will require suplicant utility to make it work.
Win2k did not have any native wireless configuration service, so that is why we need that.
Hope that helps !
~JG
Please rate if helps !
hrios Fri, 06/29/2007 - 08:40
Win2K SP4 does come with a 802.1x authentication client. It is called Wireless Configuration and it can be found under "services".It is disabled by default, though. You use this in conjunction with the configuration utility for the wireless adapter. I've been successful in connecting to a WLAN with PEAP/WEP, but I seems as though it does not work with PEAP/WPA/TKIP
Premdeep Banga Fri, 06/29/2007 - 15:33
  • Gold, 750 points or more
This is what all I was able to find,
- Funk Odyssey or Meetinghouse Aegis(Now Cisco Secure Services Client) supplicant is required to add WPA
TKIP/MIC support to the Windows 2000 operating system.
- Microsoft patch 815485 is required to add WPA TKIP/MIC support to the
Windows XP operating system.
- Microsoft patch 313664 is required to add IEEE 802.1X (i.e., PEAP)
- IEEE 802.1X (i.e., PEAP) support is native in the Windows XP SP1
operating system.
- CCX v2 is required to support PEAP, WPA TKIP/MIC, and CKIP/MIC for
non-Cisco wireless client adapter driver and firmware.
- PEAP, WPA TKIP/MIC, and CKIP/MIC are supported natively in Cisco
wireless client adapter driver and firmware using ACU or ADU.
I think tkip wont be available on w2k natively or by applying some Microsoft Patch. If you want you can get this thing verified.
Hope this Helps!
Prem
Trending Topics - Security & Network
