1242/1310: AP Authentication vs. WDS Authentication
Jun 29th, 2007
Dear colleagues,
in the 1242 you can set AP Authentication under "Security" to authenticate the AP against a Radius Server such as ACS. And if the AP becomes member of a WDS you can again define a username and a password for the AP.
Will WDS be used if I also define a username/password in the AP Authenticat. section (below Security) or will the AP then directly authenticate against the Radius Server - if it is defined there as AAA-Client ?
I'm asking because we need a failover solution for the case the 2 WDS master APs should fail - so that the Infrastructure APs will then be able to directly pass on Radius Authentication Requests to the ACS Radius Server. Thanks.
smahbub Thu, 07/05/2007 - 10:10
Radius server is configured under Wireless Domain services -settings page and User name and password for WDS is sset under AP page. However there will be atleast one AP acting as primary AP other then one in question.
Trending Topics - Security & Network
