https port other then 443 no possible with performance monitor
Jun 29th, 2007
Is there a way to import a device in the Performance Monitor (3.0) either via DCR or via CSV but the device is not listening on the default https port 443 but on 444 for instance.
Since the last update from the CSM, it now works on the CSM, but I can't import the device into the Perf. monitor.
Does anyone know if this is simply not supported or if this is a BUG.
THX
carenas123 Fri, 07/06/2007 - 06:04
  • Silver, 250 points or more
I thank you that Cisco ASDM access be configured with an HTTPS port other than 443, which prohibits Cisco Monitor Manager connections. Note that this does not apply to Cisco ASAs running software version 8.0.
Quick Start Guide for Cisco Monitor Manager 1.1 is provided in following URL please click it:
http://www.cisco.com/en/US/products/ps7244/products_quick_start09186a008084117b.html#wp64268
