Determine which port servers/clients are plugged into
Answered Question
Jun 29th, 2007
On a new Catalyst 6509 running IOS is there a way to tell which port a particular server or client is plugged into? (Without tracing patch cables)
I have done this on old switch gear with ARP and/or CAM tables. Does not appear to be the same on this new switch.
Thanks.
Correct Answer by Jon Marshall about 9 years 7 months ago
if you know the mac-address already
1) sh mac-address-table address "mac address"
If you need the IP address of the server first
1) sh arp | include "IP address".
from this you get the mac-address
2) as above.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Fri, 06/29/2007 - 06:55
2) as above.
Jon
