paolo bevilacqua Fri, 06/29/2007 - 11:44
  • Hall of Fame,
    Founding Member
Sorry, Cisco doesn't make one.
azfarlashari Mon, 08/20/2007 - 04:30
Dear, You can add two 7914 expansion modules with 7960 ip phones and have 40 to 50 lines on it.
asomanya Mon, 08/20/2007 - 11:24
The 7914s have 14 buttons and can add only 2 max, that is well short of 50 lines I am looking for.
evan.proios Wed, 08/22/2007 - 11:55
14 + 14 is 28 and if you add that to the 8 of a 7970 you will have 36. That is close. Having 50 lines on a single phone sort of defeates the purpose that Cisco built unified CM on. Did you fully explore all the other options with AC and assistant? Maybe you need to create some custom scripts with IPCC. I can't get my head around why someone would need so many lines.
