hunt problem
Jun 29th, 2007
Hi All
I have setup a hunt group as follows:
ephone-hunt 2 sequential
pilot 7828151
list 1400, 1401, 1402
timeout 10
final 600
If i call this hunt group from an internal extention say 1405 then it works as intended.
However if I call it from outside (the pilot number is a registered sip account with my sip provider)then the call comes in and rings on the first phone in the list for 10 seconds but then does not start ringing the next phone in the list.
At this point all phone stop ringing!
The strange thing is the caller continues to hear ringing and it will ring forever (i.e. it doesn't go to the final number either).
Any ideas?
Paolo Bevilacqua Fri, 06/29/2007 - 11:43
Beside that I don't know if cisco officially supports ephone-hunt from sip, it is possible that the router is trying to send some sip transfer messages and thing gets messed up.
Which IOS are you using ?
Can you collect "term mon" and "debug ccsip message", aftr configuring "service timestamps debug datetime msec" please.
Paolo Bevilacqua Sat, 06/30/2007 - 08:23
Hi Antony,
CCME is sending "temporarily not available" after 10 seconds and that ends the call.
Could you try 12.4(11)XJ3 and configure:
voice service voip
no supplementary-service sip moved-temporarily
That is the setting to make transfer work with SIP carriers. Honestly I don't know if may work with ephone-hunt, but one always hope :)
NB: you may want to avoid the failed registration attempts configuring "no-reg" on ephones and "no sip-register" on DP POTS.
anthonyfear Thu, 07/05/2007 - 10:38
12.4(11)XJ3 not available for my platform - so I tried 12.4(15) which has the command you mention.
However it still fails to hunt properly.
