FR load balancing problem
Jun 29th, 2007
Hello, I have 3 conections to my ISP. All of them are frame relay (E1), my problem is:
I configure as follow:
interface Ethernet4/1
ip address 200.109.243.129 255.255.255.248 secondary
ip address 200.44.154.185 255.255.255.248
no ip redirects
load-interval 30
interface Serial0/0
description Circuito 8151-0012318
bandwidth 1920
ip address 200.109.247.200 255.255.255.252
ip load-sharing per-packet
encapsulation frame-relay IETF
no ip mroute-cache
load-interval 30
serial restart-delay 0
fair-queue
frame-relay interface-dlci 350
frame-relay lmi-type ansi
interface Serial0/0
bandwidth 1920
ip address 200.44.111.174 255.255.255.252
no ip mroute-cache
load-interval 30
fair-queue
ip route 0.0.0.0 0.0.0.0 200.44.111.173
It works well but whe I add next ip route fron other valid network it becomes slow
example:
ip route 0.0.0.0 0.0.0.0 200.109.247.200 }
I put load-balancing per packect and per destination but it still the same.
Each conection is a E1.
Even when I make a Traceroute in the first case is very fast but when I add the second ip route and third is really slow.
How can I fix this problem? I want to use of all my links making load balancing
By now the only traffic is from my laptop nobody else is using this connections.
Leo
Edison Ortiz Fri, 06/29/2007 - 07:41
IP Address on S0/0 is invalid. That's a subnet ID. Valid hosts within that subnet are from 200.109.247.201 to 200.109.247.202.
