Issues with Roaming
d.muccillo
I have a laptop with Vista and a laptop with XP. It seems that my Vista laptop for some reason roams to a different AP on a different floor and then back. (the laptop is not moved--it is at one location).My laptop with XP seems to stay on the same AP in that same location. The XP laptop does not roam. Not clear on why this is roaming and if any settings can be tweaked. Please help.
It seems that there are 2 APs which have same range power and therefore clients is flapping between them. For a testing purpose, lower the power of 10th floor AP. It will resolve this issue.
8 Replies 8
pnegi
May I know how many APs are you using? Do you to which Ap it roamed to?
I have 4 aps per floor and 10 floors. AP1210. AP that I connect to is on the 9th floor and the AP I roam to is on the 10th floor. Again, I have 2 laptops side by side. The one running XP does not roam.
thanks. i will try this.
Thanks for your message. I will be eagerly waiting for your reply.
Or else you can try changing the channel numbers of the AP in 10 th floor and the 9th floor to be different.....
Example: AP in 8th floor - channel 1
AP in 9th floor - channel 6
AP in 10th floor - channel 10 and
AP in 11th floor - channel 1 again
And tune your laptop with vista to the concerned floor channel
See if this would help
Cheers
Dev
I am agreed with Dev. Having different non overlapping channels can also help us to avoid this problem.
Are the client cards in both laptops the same?
