FXS Port not going off hook
Jun 29th, 2007
  • Bronze, 100 points or more
We have a VIC-4Fxs/DID card inserted into a NM-HD-2V module in a 3725 router
The first two ports on the card work find but ports 3 and 4 never go off-hook. When a call comes in i see the port ringing but when i pick up the phone i hear clicks and when i hang up the phone it starts rining again.
When i try to initiate a call i get no dial tone i even tried setting for connection plar and still do not see the phone go off-hook. I verified that the port is set for loop-start signaling...
I don't think its an issue with DSPs
any help is appreciated.
----------------------------FLEX VOICE CARD 2 ------------------------------
*DSP VOICE CHANNELS*
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABRT PACK COUNT
C5510 001 01 g711ulaw 4.4.704 busy idle 0 0 2/0/0 00 0 206/136
*DSP SIGNALING CHANNELS*
C5510 001 01 {flex} 4.4.704 alloc idle 0 0 2/0/0 02 0 105/0
C5510 001 02 {flex} 4.4.704 alloc idle 0 0 2/0/1 02 0 188/0
C5510 001 03 {flex} 4.4.704 alloc idle 0 0 2/1/3 02 0 59/0
C5510 001 04 {flex} 4.4.704 alloc idle 0 0 2/1/2 02 0 29/0
C5510 001 05 {flex} 4.4.704 alloc idle 0 0 2/1/1 06 0 184/0
C5510 001 06 {flex} 4.4.704 alloc idle 0 0 2/1/0 06 0 112/0
------------------------END OF FLEX VOICE CARD 2 ----------------------------
paolo bevilacqua Fri, 06/29/2007 - 11:34
  • Hall of Fame,
    Founding Member
Hi, can you check that in the connector into the card, only the two central wires are present, and nothing else ?
