Phone Change Logs
Jun 29th, 2007
I am trying to find the logs that show when a 7960 phone was added or modified in CCM4.1(2). Does anyone know where this log file might be located? Thanks in advance.
gogasca Sat, 06/30/2007 - 17:33
  • Green, 3000 points or more
If you are using MLA you can find them under Program Files|Cisco|Trace|MLA
Otherwise I only would check IIS logs.
Or start thinking in CUOM or other Cisco Management Tool for Access.
