Question: Clearing QoS Statistics on CAT 3750G
Jun 29th, 2007
Is anyone familiar with the command to clear QoS statistics on a 3750G. There is nothing in the command reference guide and I have tried the following to no avail:
Clear counters
Clear access-list counters
clear tcp statistics
Clear vmps statistics
Overall Rating: 5 (2 ratings)
Edison Ortiz Fri, 06/29/2007 - 11:07
clear counter works just fine here.
Are you talking about the stats you get while typing
show policy-map interface ?
wmacleod2 Fri, 06/29/2007 - 11:44
I was using the CNA Tool which allows you to view a count of DSCP and COS specific packets on the ingress and egress side of a port.
The counters were not clearing when I issued the clear counter command. I just tried the CLI show policy-map command as you suggested and verified that the counters are cleared so I am not sure what to make of this discrepency?
Are they different counters in the MIB perhaps?
Edison Ortiz Fri, 06/29/2007 - 11:50
Sorry, I can't tell you where exactly the CNA tool is reading the information from. Always trust the good old CLI (Command Line Interface) :)
wmacleod2 Fri, 06/29/2007 - 12:03
I am guessing the CNA is extacting the information from somewhere in the MIB but perhaps these counters are not controllable from the CLI and cannot be cleared manually.
Thank-you for your help.
MUHAMMAD SHAHEEN Mon, 07/02/2007 - 05:11
Yes, you can clear QOS counters/stats for all ports or for a specific port using the command line.
If you want to clear QOS stats/counters from all the interfaces then issue this command
C3750Switch#clear mls qos interface statistics
and for a specific interface issue this command. for example....
C3750Switch#clear mls qos interface fastEthernet 1/0/1 statistics
Shaheen
Pavel Bykov Mon, 07/02/2007 - 02:49
I don't think it's a MIB issue. My guess is that CNA tool is storing information somewhere locally. Try finding a way to clear counters there, or connect to different interface on a router, if it's storing it's statistics per IP.
If nothing, then try "clear counters" on router, and then using newly installed tool on a different machine - to see if the information will be with cleared counters or with the old ones. This would certainly pinpoint the location of the problem - MIB or Application.
David Stanford Tue, 07/03/2007 - 19:26
Keep in mind that most CLI clear commands do not clear MIB counters. The only way to clear a MIB counter is reload of the device.
