VoIP SBC Problems
I am trying to configure SBC on a 7200 router to allow non-sip complient router/fw's on the outside to use our VoIP infrastructure - in this case a connection to our AS5300 and out to the PSTN.
I have the following configuration that allows me to connect but I don't get any sound.
Does anyone have a working SBC configuration I can take a look at?
Anthony
paolo bevilacqua Fri, 06/29/2007 - 11:38
  • Hall of Fame,
    Founding Member
Do they use use SIP ? Do you use NAT ? Which IOS do you have on the 7200 ?
Yep, SIP is the protocol. The flow of things is as follows:
1. Client uses SIP softphone to connect to our global IP
2. That hits my 7206(12.4(11)T2 IOS) and gets NAT'd via SBC -- this is the part that isn't really working!
3. Then hits my PIX515E FW and that global address is translated to an internal address and then hits the router.
I have the following config in place:
ip nat sip-sbc
proxy 5060 5060 protocol udp
session-timeout immediate
mode allow-flow-around
override address
ip nat translation timeout 10
ip nat translation tcp-timeout 10
ip nat translation udp-timeout 10
ip nat pool call-id-pool 192.168.201.1 192.168.201.254 netmask 255.255.255.0
ip nat inside destination list 111 pool call-id-pool
As I say, the call connects but I just don't get any sound....
paolo bevilacqua Fri, 06/29/2007 - 16:27
  • Hall of Fame,
    Founding Member
Hi Antonony,
I'm not familiar on the sip-sbc configuration and don't know the specifics on that. What I can tell you, I have a SIP phone working ok through regualt NAT (inside to outside) with same IOS as yours - no configuration required.
The other day also tried a PIX with a static NAT configuration (1 to 1 mapping), again, no problem.
Sorry I can't tell what the problem is, perhaps you could try to take one of the two NAT out of the equation and see if that helps.
