CUE AA Dial by name
Jun 29th, 2007
I am trying to configure Auto Attendant using my CUE and using the default prompt. The "Dial by name" option in the AA is not working.
I have users created in my CUE as well as their mailboxes. But when any caller call this AA and press 2 for option Dial by name, he is asked to enter the first name and last name. But after giving this inputs, the system says a message like " system can not find the name of the person you have entered".
Can anyone help me find if I am missing anything here ?
Pete
ouhakheme Sat, 06/30/2007 - 07:19
To my knowledge it should be last name then first name. Do you have the script handy? If not I should have one that I can share with you.
twissam Sun, 07/01/2007 - 10:46
it should work, dumble for instance should be:
386253 on the keep pad.
Good luck.
Rob Huffman Sun, 07/01/2007 - 14:37
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Pete,
Maybe you are hitting this;
For Cisco Unity Express release 2.1.1, when Maximum Retries on the NameToUser step is set to 0or 1, you must use a Terminating Key character. Without the Terminating Key character, the step does not go to the Successful branch of this step. Instead, the step always goes to the Timeout branch, even if there is a match.
From this doc;
Cisco Unity Express 2.3 Guide to Writing Auto-Attendant Scripts
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_administration_guide_chapter09186a008067a18b.html
Hope this helps!
Rob
